1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca gateway problem
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 4 May 2016 10:02:42 +0200
On 04/05/2016 06:36, Silver wrote:
when I test ca gateway, I write the access file like:
ASG(DEFAULT) {
  RULE(0,READ)
then can't access the  PV from server side.
If changing to RULE(1,READ), that's ok. I think for level0, it should be able to access the VAL field, but why can't here?
thanks a lot for your help.
Hi Geyang,
While the GW uses the same access security library as the IOC, the assignment of AS levels is different.
The GW is proxying pure Channel Access connections. As it does not know about the concepts of the EPICS database, terms like "record" or "field" do not have a meaning inside a GW.
Instead, access security levels are assigned in the GW's pvlist file. Its pattern lines may contain an <asl> value, e.g.
    <pv-name-pattern> ALLOW [<asg> [<asl>]]
The specified access security level is assigned to *all* PVs that match the <pattern>.
See the GW documentation [1] for more details.
Cheers,
~Ralph
[1] http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/Gateway/Gateway.html#AccessSecurity
ca gateway problem Silver
Prev: Re: Re: ca gateway problem Ralph Lange
Next: RE: Reg programming in EPICS environment for master slave control Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Match calloc() with free() for asynNDArrayDriver::pArrays Henrique Almeida
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
