1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Required help about mobbus tcp module
Date: Sat, 7 May 2016 13:47:07 +0000 (UTC)
Dear rivers
i have just started working in epics. i am using its modbus tcp module for
accessing plc it works well.i have plc simulator when i access that with modbus tcp
module using epics it works well. i am facing a problem that i want to write a output
on coil register at index 0. i have designed simple boplc block for this puprpose it works well.
i want to give input signal to boplc record from bi1 recrod. for this i give the name of bi1 in the
DOL filed of boplc record. it make the connection but give the "warning message that Desired Output loc: warninig :bi1 doesnot match the pattern  @.*"
when i load the database it loaded successfully but when i change signal value of bi1 it change sucessfully but did not shift to boplc recrod.
can you please help how to shift bi1 record value to boplc recrod. i have attached snaps of database record field.
for simple records when we are not using any device support we can shift value one record to other record just by giving name in DOL field.
wait for yor reply
best regards
sajid
Attachment: figure1.gif
Description: GIF image
Attachment: figure2.gif
Attachment: plcdb.db
Description: Binary data
RE: Required help about mobbus tcp module Mark Rivers
Re: Required help about mobbus tcp module Dirk Zimoch
Prev: Re: Recommendation on a PCIe ADC board Jameson Graef Rollins
Next: how to plot Process Value in css databrowser with ca port 9004 ? lzfneu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: antelope error in Windows 7 cygwin build of EPICS base 3.15.3 Ana Malagon
Next: RE: Required help about mobbus tcp module Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
