1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Race condition in db_get_field_and_count() (3.14.12)
To: [email protected]
Date: Tue, 10 May 2016 19:18:43 -0700
Still present on 3.15 and 3.16 branches/heads
On 05/10/2016 07:10 PM, Till Straumann wrote:
Dehong reported the following bug:
In order to convert between legacy and more 'modern' representation of
data with at least DBR_STATUS auxiliary information
db_access.c: db_get_field_and_count()
calls dbGetField() twice; a first time to retrieve the auxiliary information
(status, timestamps, ...) and a second time to fetch data.
Since the underlying record is not locked across the two calls to dbGetField()
the record could be processed in between and render the auxiliary data
invalid/obsolete.
Proposed fix:
AFAIK, dbScanLock() supports recursion and therefore the easiest
fix would be acquiring the record lock within db_get_field_and_count()
RFC
- Till
PS: the bug seems to still be present in the 3.14 branch head
Race condition in db_get_field_and_count() (3.14.12) Till Straumann
Prev: Race condition in db_get_field_and_count() (3.14.12) Till Straumann
Next: Re: Reg programming in EPICS environment for master slave control Himanshu Tyagi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Race condition in db_get_field_and_count() (3.14.12) Williams Jr., Ernest L.
ANJ, 11 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
