1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Question about Archive Engine
Date: Fri, 13 May 2016 05:11:01 +0000
hi,
I encounter a problem when archive engine takes the data from ioc via channel access and place the data to mysql database. Here is the details in termintor window:
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 65,099,938 milliseconds ago.  The last packet sent successfully to the server was 65,099,971 milliseconds ago.  is longer than the server configured value of 'wait_timeout'.  You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
It seems the connection is timeout.
I have downloaded the mysql-connector-java-5.1.39.tar.gz, unzip it and add CLASSPATH to the mysql-connector-java-5.1.39-bin.jar in the .bashrc file.
I am not quite familar with JAVA and my question is, according to the tips in terminal window, where to set the Connector/J connection property 'autoReconnect=true' to avoid this problem.
Any help will be appreciate and thanks in advance !
Zhefu
Re: Question about Archive Engine Kasemir, Kay
Prev: RE: long string command to device Gofron, Kazimierz
Next: Micronix MMC-200 motor controller 김지화(빔라인장치팀)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Long string command to device Bo Jakobsen
Next: Re: Question about Archive Engine Kasemir, Kay
ANJ, 26 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
