1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problems about Streamdevice when sending hex command to motor device
To: 李姣赛 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 24 May 2016 16:44:18 +0000
There were no attachments with your message, so we cannot see your .db, .proto, and .cmd files.
From: [email protected] [[email protected]] on behalf of 李姣赛 [[email protected]]
Sent: Tuesday, May 24, 2016 8:52 AM
To: [email protected]
Subject: Problems about Streamdevice when sending hex command to motor device
Recently I try to use Streamdevice to control a motor device. The form of the command is hex as follow:
command                                                     Hex-ASCII                                    & nbsp;
vertical init             05 30 30 46 46 57 57 30 44 30 30 30 32 30 31 30 37 44 30
angle                     05 30 30 46 46 57 57 30 44 30 30 30 30 30 31 30 37 44 30                      &nbs p;
        (last four numbers stand for rotation angle: 07D0)
start                      05 30 30 46 46 57 57 30 4D 30 30 30 32 30 31 30 30 30 31
stop                ;        05 30 30 46 46 57 57 30 4D 30 30 30 32 30 31 30 30 30 30
read                      05 30 30 46 46 57 52 30 44 38 33 34 30 30 31
        When record type is "aao" or "aai", I send an array angle command(e.g.  05 30 30 46 46 57 57 30 44 30 30 30 30 30 31 30 37 44 30) and I received the reply value correctly on NewNetAssistant. The reply value is "-00FF" as follow:
[X]
But, when I test it on streamdevice, there are some errors:
1. Format convert is not ok:
2. The reply values are none:
[X]
3. When assigning values on PV values, it get only the former 13 values rather than all(in fact, I need assign 19 values to the PV values and it loss the last 6 values), as shown on the up picture.
When record type is "ao" or "ai", no format convert errors occured, but the PV value only accept the first 1 value and return 0:
My fx3uplc.db    fx3uplc.proto    fx3uplc.cmd are as follow:
[X]
[X]
I'm figuring out which type should I choose such that the reply values are correct. I'm so anxious.
Thanks very much and best wishes!
                       Jiaosai Li, IMPCAS
Problems about Streamdevice when sending hex command to motor device 李姣赛
Prev: pyepics 3.2.5 Matt Newville
Next: Re: EPICS meeting : HW platform support discussion group Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problems about Streamdevice when sending hex command to motor device 李姣赛
Next: Re: Problems about Streamdevice when sending hex command to motor device Dirk Zimoch
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
