1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Unable to initialize parameter with setStringParam()
To: Henrique Almeida <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Wed, 1 Jun 2016 14:45:26 -0400
HI Henrique,
I think what is happening is that NDFileTempSuffix has its associated $(P)$(R)TempSuffix record with PINI=YES and VAL="", so the record initialization that happens after your constructor is clearing the value (https://github.com/areaDetector/ADCore/blob/master/ADApp/Db/NDFile.template#L366).
I think the same happens to NDFileTemplate.
HTH,
Bruno
On Wed, Jun 1, 2016 at 2:25 PM, Henrique Almeida <[email protected]> wrote:
 Hello, while constructing an areaDetector object, I'm unable to
successfully initialize string parameters with setStringParam(). For
example, calling setStringParam(NDFileTemplate, "abcd") or
setStringParam(NDFileTempSuffix, "xyz") has no effect and the
corresponding PVs, FileTemplate_RBV and TempSuffix_RBV stay empty. Any
help ?
 Note: I can successfully initialize integer parameters with setIntegerParam().
Re: Unable to initialize parameter with setStringParam() Henrique Almeida
RE: Unable to initialize parameter with setStringParam() Mark Rivers
Prev: Unable to initialize parameter with setStringParam() Henrique Almeida
Next: Re: Unable to initialize parameter with setStringParam() Henrique Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
