Hi Mark,
On 06/03/2016 12:16 PM, Mark Rivers wrote:
> casr showed some things like this that look suspicious?
> TCP 164.54.160.93:51762(Ferrari): User="XAS_User", V4.13, 677 Channels,
> Priority=0
> Task Id=0x7a24820, Socket FD=75
> Secs since last send 593.58, Secs since last receive 593.58
> Unprocessed request bytes=16, Undelivered response bytes=5192
> State=up jumbo-send-buf
> Any ideas, and things to look at if I am able to reproduce the problem?
This might be a hung client program which would explain the problem, do
you recognize it? Look for the CA client running on Ferrari with a TCP
socket open on port 51762 (hint below).
In general to find hung clients you can run inetstatShow and look for
TCP connections that have large numbers in the Send-Q column, then go
and identify the specific client with that connection. You will have to
do that through the port number in the "Foreign Address" column, and
find which process on that workstation actually has a TCP socket open
with that port number; on Linux the 'lsof' program can do this if you
can login as the same user as the client or as root, although the
arguments to lsof are rather obscure (try 'lsof -i4:5064 -Tqs').
- Andrew
- Questions about devIocStats on vxWorks Mark Rivers
Problem in updating EGU field in CSS-BOY Shantonu Sahoo
<2016>
2025
2026
RE: Questions about devIocStats on vxWorks Allison, Stephanie
<2016>
2025
2026
