1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PCASpy 0.6
To: "Wang Xiaoqiang (PSI)" <[email protected]>
Cc: epics <[email protected]>
Date: Mon, 6 Jun 2016 09:58:49 -0300
 I'm trying to do a pip install, but I'm getting the following error. Any help ?
sol5-linux:/home/ABTLUS/henrique.almeida # pip3 install pcaspy
    gcc -pthread -DDYNAMIC_ANNOTATIONS_ENABLED=1 -DNDEBUG -O2 -g -pipe
-Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
--param=ssp-buffer-size=4 -m64 -mtune=generic -D_GNU_SOURCE -fPIC
-fwrapv -fPIC -I/usr/local/epics/base/include
-I/usr/local/epics/base/include/os/Linux -I/usr/include/python3.4m -c
pcaspy/casdef_wrap.cpp -o
build/temp.linux-x86_64-3.4/pcaspy/casdef_wrap.o
    In file included from /usr/local/epics/base/include/epicsTypes.h:20,
                     from /usr/local/epics/base/include/epicsString.h:20,
                     from /usr/local/epics/base/include/resourceLib.h:45,
                     from /usr/local/epics/base/include/fdManager.h:26,
                     from pcaspy/casdef_wrap.cpp:3589:
    /usr/local/epics/base/include/compilerDependencies.h:19:30: error:
compilerSpecific.h: Arquivo ou diretório não encontrado
2016-06-06 9:43 GMT-03:00 Wang Xiaoqiang (PSI) <[email protected]>:
> Yes. I have tested the examples with python 3.4/3.5.
> -----Original Message-----
> From: Henrique Almeida [mailto:[email protected]]
> Sent: Montag, 6. Juni 2016 14:37
> To: Wang Xiaoqiang (PSI)
> Cc: epics
>  Xiaoqiang, does it work with python 3.3 or later ?
> 2016-06-06 5:32 GMT-03:00 Wang Xiaoqiang (PSI) <[email protected]>:
>> Hi,
>> Here is the much delayed 0.6 release of PCASpy.
>> The repo has moved from the deceased googlecode to github.
>> The project page at PyPI [1] has the source and binary downloads.
>> It contains the following fixes.
>>     Warns and truncates if enums type PV has more than 16 states or any state string length > 25. (Issue #18)
>>     Fixed that PV of char type cannot be set to empty string. (Issue #14)
>>     Fixed that DBE_ALARM event was not posted. (Issue #13)
>>     Added support of request type DBR_CLASS_NAME in casPV base class. It is not overloaded in SimplePV. The default implementation returns an empty string.
>> Best
>> Xiaoqiang
>> [1] https://pypi.python.org/pypi/pcaspy
RE: PCASpy 0.6 Wang Xiaoqiang (PSI)
Re: PCASpy 0.6 Henrique Almeida
Prev: RE: PCASpy 0.6 Wang Xiaoqiang (PSI)
Next: RE: PCASpy 0.6 Wang Xiaoqiang (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
