1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems building 'database' from exampleCPP
To: "Gibbs, Matt" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 6 Jun 2016 18:34:31 -0500
Hi Matt,
On 06/06/2016 04:37 PM, Gibbs, Matt wrote:
> I'm trying to build the 'database' example from the V4 C++ examples
> project (https://github.com/epics-base/exampleCPP).
Are you trying to build the github master branch tip of exampleCPP
against a V4.5.0.x release version of the other V4 modules? That
particular combination probably isn't compatible since there have been
many changes and additions to the exampleCPP module recently that depend
on newer versions of the other V4 modules.
Unfortunately that probably means that the particular example you're
looking for won't be available in the appropriate release version of the
exampleCPP module (from the release/4.1 branch). We're currently working
on the next major release 4.6.0 which will include the new examples
though, so you might want to try checking out and building the master
branch of all the V4 modules.
I have a git super-module which has submodules for all the V4 C++
modules including the example module, so you can try following the
simple instructions in the README.md at
    https://github.com/anjohnson/pvPackageCPP
HTH,
- Andrew
Re: Problems building 'database' from exampleCPP Gibbs, Matt
Prev: Problems building 'database' from exampleCPP Gibbs, Matt
Next: Re: Problems building 'database' from exampleCPP Gibbs, Matt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
