1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Merlin and AreaDetector
Date: Fri, 10 Jun 2016 22:19:05 +0000
Dear all,
For Merlin Quad detector, I compiled ADMerlin with newest AreaDetector (2.5?), and things seem to work properly. However, for the current application, we need 6 ROI regions, but AD provides only 4 ROI regions. Would increasing number of ROI regions to 6 in areaDetector be standardized?
2. I am also seeing the "labview" messages in the ioc which may or may not be important.I am wondering if this is anything to worry about???
iocInit()
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Dec  2 2015
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from '/epics/iocs/merlinIOC/as/save/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
*** restoring from '/epics/iocs/merlinIOC/as/save/auto_settings.sav' at initHookState 7 (after record/device init) ***
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 57841,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=XF:10IDD-ES{Merlin:1}")
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
epics> auto_settings.sav: 826 of 826 PV's connected
2016/06/10 18:02:42.811 medipixDetector:mpxReadCmd error, status=1 unexpected response from labview: ''
2016/06/10 18:02:42.811 medipixDetector:writeFloat64 error, status=1 function=91, value=20.000000
2016/06/10 18:02:42.812 XF:10IDD-ES{Merlin:1}cam1:OperatingEnergy devAsynFloat64 pPvt->result.status=1, process error
2016/06/10 18:02:44.814 medipixDetector:mpxReadCmd error, status=1 unexpected response from labview: ''
2016/06/10 18:02:46.815 medipixDetector:mpxReadCmd error, status=1 unexpected response from labview: ''
2016/06/10 18:02:47.155 medipixDetector:mpxReadCmd error, status=0 unexpected response from labview: 'MPX,0000000022,CMD,STOPACQUISITION,0'
2016/06/10 18:02:47.162 medipixDetector:mpxReadCmd error, status=0 unexpected response from labview: 'MPX,0000000022,SET,OPERATINGENERGY,0'
2016/06/10 18:02:47.166 medipixDetector:mpxReadCmd error, status=0 unexpected response from labview: 'MPX,0000000017,SET,THRESHOLD0,0'
2016/06/10 18:02:47.169 medipixDetector:mpxReadCmd error, status=0 unexpected response from labview: 'MPX,0000000027,GET,THRESHOLD0,10.000000,0'
2016/06/10 18:02:47.186 medipixDetector:writeFloat64 error, status=1 function=83, value=10.000000
2016/06/10 18:02:47.186 XF:10IDD-ES{Merlin:1}cam1:ThresholdEnergy0 devAsynFloat64 pPvt->result.status=1, process error
epics>
Kazimierz
RE: Merlin and AreaDetector Mark Rivers
Prev: Re: EPICS Archiver Appliance Konrad, Martin
Next: RE: Merlin and AreaDetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS support for LonWorks field bus? Hartman, Steven M.
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
