1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem in base 3.15.x at runtime
To: "EPICS Tech-Talk" <[email protected]>
Cc: Anindya Roy <[email protected]>
Date: Wed, 15 Jun 2016 14:54:28 +0530
I am using EPICS base 3.15.2 and asyn4-29 to build an IOC. I could successfully build the IOC without any error. But, when I run it, I get the an error attached below. I do not get any error if I use 3.14.12.5 base version. So, I can certainly conclude that it's a bug with 3.15.x version.
Successfully locked memory using mlockAll
#!../../bin/linux-x86_64/Y
## You may have to change Y to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","ioccurrentmeter")
epicsEnvSet("TOP","/home/work/base-3.15.2/asyn4-29/currentmeter")
epicsEnvSet("ASYN","/home/work/base-3.15.2/asyn4-29")
epicsEnvSet("EPICS_BASE","/home/work/base-3.15.2")
cd /home/work/base-3.15.2/asyn4-29/currentmeter
dbLoadDatabase("dbd/currentmeter.dbd",0,0)
dbLoadDatabase("dbd/devcurrentmeter.dbd",0,0)
currentmeter_registerRecordDeviceDriver(pdbbase)
A call to 'assert(prt->no_fields == 308)'
    by thread '_main_' failed in ../O.Common/aSubRecord.h line 659.
Dumping a stack trace of thread '_main_':
[    0x7f3c1fad2fcb]: /home/work/base-3.15.2/asyn4-29/currentmeter/lib/linux-x86_64/libCom.so.3.15.2(epicsStackTrace+0x4b)
[    0x7f3c1facc62a]: /home/work/base-3.15.2/asyn4-29/currentmeter/lib/linux-x86_64/libCom.so.3.15.2(epicsAssert+0x4a)
[    0x7f3c1ff8cd16]: /home/work/base-3.15.2/asyn4-29/currentmeter/lib/linux-x86_64/libdbRecStd.so.3.15.2(aSubRecordSizeOffset+0x36)
[    0x7f3c1fd53cd8]: /home/work/base-3.15.2/asyn4-29/currentmeter/lib/linux-x86_64/libdbCore.so.3.15.2(registerRecordTypes+0xc8)
[          0x405ba0]: /home/work/base-3.15.2/asyn4-29/currentmeter/bin/linux-x86_64/currentmeter(currentmeter_registerRecordDeviceDriver+0x60)
[    0x7f3c1fabebb0]: /home/work/base-3.15.2/asyn4-29/currentmeter/lib/linux-x86_64/libCom.so.3.15.2(iocshBody+0xae0)
[          0x405a32]: /home/work/base-3.15.2/asyn4-29/currentmeter/bin/linux-x86_64/currentmeter(main+0x12)
[    0x7f3c1f25eec5]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)
[          0x405a7d]: /home/work/base-3.15.2/asyn4-29/currentmeter/bin/linux-x86_64/currentmeter(_start+0x29)
EPICS Release EPICS R3.15.2 $Date: Thu 2015-05-14 14:09:28 +0200$.
Local time is 2016-06-15 20:17:18.833637915 IST
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
Shantonu Sahoo
VECC
RE: Problem in base 3.15.x at runtime Mark Rivers
RE: Problem in base 3.15.x at runtime Shantonu Sahoo
Re: Problem in base 3.15.x at runtime Michael Davidsaver
Prev: Re: Error msg Stefen Paul
Next: RE: Problem in base 3.15.x at runtime Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Open Positions at SLAC: Senior Software Application Developer and Architect Williams Jr., Ernest L.
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
