1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Access TIME field of a PV
To: Elmer Pensack <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 15 Jun 2016 14:36:25 +0000
You can see the latest timestamp on any displayed PV  by right-mouse-button -> PV Info and then select the desired field.  If you want the time displayed continuously then follow Mark's link.
  Ned
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Wednesday, June 15, 2016 09:32 AM
To: Elmer Pensack; [email protected]
There is device support in EPICS base for a stringin record to display the timestamp of a record.  Look at this tech-talk note:
http://www.aps.anl.gov/epics/tech-talk/2006/msg00017.php<http://www.aps.anl.gov/epics/tech-talk/2006/msg00017.php>
From: [email protected] [[email protected]] on behalf of Elmer Pensack [[email protected]]
Sent: Wednesday, June 15, 2016 9:06 AM
To: [email protected]
Subject: Access TIME field of a PV
Hello,
I have a MEDM display with several text message PVs. The users want to know when the PVs last updated because they don’t update frequently, I thought it would be easy - I’d just display the TIME field next to the message, only to find that TIME is not accessible. So is there an easy way to display the last update time? I was hoping not to need to write code to do it.
Thanks for any suggestions.
Elmer Pensack
Access TIME field of a PV Elmer Pensack
RE: Access TIME field of a PV Mark Rivers
Prev: RE: Access TIME field of a PV Mark Rivers
Next: Pending pull requests Henrique Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Access TIME field of a PV Southern, Tim
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
