Thank you all for the input.Removing the -DEPICS_NO_DLL From the compile line solved it for me. Might as well update MCA maintainer with this info.
Best regards, Hinko On Friday, 17 June 2016, Andrew Johnson < [email protected]> wrote: Hi Hinko,
On 06/17/2016 01:55 AM, Hinxx wrote:
> I'm also not sure if the -DWIN32 is adequate in MCA compile line - I
> want 64-bit mca mex object.
IIRC the -DWIN32 flag is used for all target builds that use the EPICS
Windows implementations in libCom and the MSVC compiler, even when the
target is actually a 64 bit CPU.
- Andrew
-- .. the more I see the less I believe.., AE AoR
- MCA under windows7 64-bit Hinxx
- Re: MCA under windows7 64-bit Andrew Johnson
EPICS connect to PLC:Illegal field value PV ;Connection timed out XU Jie
<2016>
2025
2026
<2016>
2025
2026
