1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streams drivers
To: Ralph Lange <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 23 Jun 2016 09:36:34 -0400
Mark's suggestion :
Doing a git clone of the repository & rebuilding everything did it.
Thanks for your input
Peter Blanco Test/Software Eng. Kepco Inc.
To: Peter Blanco <[email protected]>
Sent: 6/22/2016 9:05 AM
Hi Peter,
Can you show how your records' links look like, and the StreamDevice protocol you are using?
NB: You should not compile StreamDevice inside EPICS Base. But that's not necessarily connected to the issues you see.
Cheers,
~Ralph
On 22/06/2016 14:49, Peter Blanco wrote:
Hello,
I'm trying to use the “Glassman” Power Supply driver which uses streams, also tried a couple other streams drivers & also went through the tutorial steps to build one from scratch, all have same problem.
Below is a screen printout that I got when running the "Glassman" driver TestApp .
I believe the problem may be with the StreamDevice itself.
The only place I could build StreamDevice without getting errors was EPICS/base, otherwise it would complain about not finding stuff.
Re: streams drivers Ralph Lange
Prev: Re: streams drivers Peter Blanco
Next: FAREX SR Mini HG System ? Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streams drivers Ralph Lange
Next: RE: streams drivers Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
