1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streams drivers
Cc: [email protected]
Date: Mon, 27 Jun 2016 10:33:04 +0200
I have tried to add “configure” but got stuck when it seemed that for each EPICS release, the configure is a bit different. A configure created with 3.14.12 did not work with 3.14.8 for me. Maybe if I find some time, I will try again.
Dirk
On 23.06.2016 19:12, Andrew Johnson wrote:
Dirk,
On 06/22/2016 04:45 PM, Hu, Yong wrote:
@Dirk, why do not you include “configure” in your official StreamDevice
release?
I am considering switching the StreamDevice links on the EPICS website
to point to the synApps github repo, since your releases have been an
unfortunate cause of confusion and time-wasting for many new EPICS users
like Peter and Yong.
I understand that the module is designed to be able to build on both
Base-3.14 and Base-3.13, but I suspect that only PSI uses StreamDevice
on Base-3.13.  The rest of the community would much prefer to download a
standard 3.14 module, edit the configure/RELEASE file and run 'make'.
Since you now use git which supports submodules, would you consider
using something like that to make releases that build under Base-3.14
and higher right out of the box?
- Andrew
RE: streams drivers Mark Rivers
Re: streams drivers Peter Blanco
Re: streams drivers Hu, Yong
Re: streams drivers Andrew Johnson
Prev: EPICS connect to siemens PLC317-2PN/DP: connetction problem XU Jie
Next: question of data conversion Remi Faure
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streams drivers Andrew Johnson
Next: ETHERCAT-4-3 on linux-arm yann
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
