1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bit shifting operators
To: "[email protected]" <[email protected]>, [email protected]
Date: Tue, 28 Jun 2016 12:57:25 +0200
Hey,
you could use a CALC record to get the individual fields of the 16-bit value.
I'm using a similar ADC where bit 15 is an ALERT-flag, bits 14-12 code the channel,
and bits 11-0 hold the conversion result.
For accessing these three values I'm using:
record( longin, "AD7998:$(ID):CONVERSION:RESULT__" ) {
  field( DTYP, "stream" )
  field( INP,  "@ad7998.proto rConv($(ID)) I2C" )
  field( FLNK, "AD7998:$(ID):CONVERSION:RESULT:SPLIT__" )
record( calc, "AD7998:$(ID):CONVERSION:RESULT:SPLIT__" ) {
  field( INPA, "AD7998:$(ID):CONVERSION:RESULT__ NPP NMS" )
  field( CALC, "b := (( A & 32768 ) >> 15 ); c := (( A & 28672 ) >> 12 ); ( A & 4095 )" )
  field( FLNK, "AD7998:$(ID):CONVERSION:FANOUT__" )
Field B of the CALC records contains the alert flag, field C the channel number
and VAL the actual conversion result.
Hope that helps.
Cheers,
Florian
On 06/28/2016 11:30 AM, [email protected] wrote:
Hello,
I am trying to read the voltag from an 8-channel adc via I2C.
My result is a 16 bit value (for example 0010 0000 0010 0000). The bits15-12 "0010" respresent the channel (Ch1=0, CH2=1, CH3=2 ....).
I can get the channel value with a SHFT-field:
record( longin, "ADC:RESULT" ) {
  field( INP,  "@adc.proto readReg($(ID)) I2C" )
record( mbbiDirect, "ADC:RESULT:CHANNEL" ) {
  field( DTYP, "Raw Soft Channel" )
  field( INP,  "ADC:RESULT.VAL")
  field(SHFT, "12")
Now I want to get the first bits 0-12 and convert the value to voltage-value. To convert this value I use the "ASLO"-field.
But I don't know which is the best way to get the value of the first 12 bits.
Raul
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29608         |
Re: bit shifting operators Florian Feldbauer
bit shifting operators [email protected]
Prev: bit shifting operators [email protected]
Next: Re: bit shifting operators Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
