I solved by setting $(SYS):$(MOD):CONVERT_CMD both as input and output (CA link
type, otherwise I don't receive the updated value as output) and avoiding
infinite calling loop by returning 1 if CONVERT_CMD value is 0.
I'm steel open to comments and suggestions on this method to solve the problem
(I have the feeling there are better ways).
Cheers,
LucaOn mer, 2016-07-13 at 12:18 +0000, Luca Cavalli wrote:
> Dear all,
> I have to perform a conversion of a set of coordinates using an aSub record.
> I have set the SCAN field of the record to passive and any change in a bi
> record
> ($(SYS):$(MOD):CONVERT_CMD) triggers the processing.
> This is an extract of the database:
> record(bi, "$(SYS):$(MOD):CONVERT_CMD") {
> field(DESC, "Convert command.")
> field(PINI, "NO")
> field(UDF, "0")
> field(FLNK, "$(SYS):$(MOD):COORD_CONVERTER")
> field(VAL, "0")
> field(ZNAM, "DONE")
> field(ONAM, "CONVERT")
> record(aSub, "$(SYS):$(MOD):COORD_CONVERTER") {
> field(INAM, "convAsubInit")
> field(SNAM, "convAsubProcess")
> field(FTA, "DOUBLE")
> field(INPA, "$(SYS):$(MOD):SRVY:RA_SET_POS PP")
> field(DESC, "Coordinate converter.")
> field(SCAN, "Passive")
> field(INPB, "$(SYS):$(MOD):SRVY:DEC_SET_POS PP")
> field(INPC, "$(SYS):$(MOD):SRVY:X_SET_POS PP")
> field(INPD, "$(SYS):$(MOD):SRVY:Y_SET_POS PP")
> field(INPE, "$(SYS):$(MOD):SRVY:Z_SET_POS PP")
> field(INPF, "$(SYS):$(MOD):SRVY:START_TIME PP")
> field(INPM, "$(SYS):$(MOD):CONVERT_CMD")
> field(FTB, "DOUBLE")
> field(FTC, "DOUBLE")
> field(FTD, "DOUBLE")
> field(FTE, "DOUBLE")
> field(FTF, "DOUBLE")
> field(FTM, "ENUM")
> Is this the proper way to achieve this task?
> How to reset the $(SYS):$(MOD):CONVERT_CMD value to 0 from the C code of the
> convAsubProcess function?
> Does this change from 1 (CONVERT) to 0 (DONE) will trigger an additional call
> to convAsubProcess?
> Thanks for your help.
> Luca
> ________________________________
> << Le informazioni contenute in questo messaggio di posta elettronica e
> relativi allegati sono riservate e confidenziali e ne è vietata la diffusione
> in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente
> messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile
> comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del
> Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
> << This e-mail is confidential and may well also be legally privileged. If you
> have received it in error, you are on notice of its status. Please notify us
> immediately by reply e-mail and then delete this message from your system.
> Please do not copy it or use it for any purposes, or disclose its contents to
> any other person: to do so could be a breach of confidence. Thank you for your
> co-operation. Please contact our IT Helpdesk on +3902380481 or email it@cgspac
> e.it if you need assistance >>
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
- Trigger aSub record from bi record reflecting status Luca Cavalli
RE: Trigger aSub record from bi record reflecting status Mooney, Tim M.
Re: EPICS archiver appliance redundancy Eric Berryman
<2016>
2025
2026
Re: Trigger aSub record from bi record reflecting status Luca Cavalli
EpicsQT and Archiver Appliance rory.clarke
<2016>
2025
2026
