1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with procServ on RHEL6
Date: Thu, 14 Jul 2016 13:22:11 -0700
The SO_REUSEPORT option provides this capability — see https://lwn.net/Articles/542629/ for the full article.  Here’s a summary:
The basic concept of SO_REUSEPORT is simple enough. Multiple servers (processes or threads) can bind to the same port if they each set the option as follows:
So long as the first server sets this option before binding its socket, then any number of other servers can also bind to the same port if they also set the option beforehand. The requirement that the first server must specify this option prevents port hijacking—the possibility that a rogue application binds to a port already used by an existing server in order to capture (some of) its incoming connections or datagrams. To prevent unwanted processes from hijacking a port that has already been bound by a server using SO_REUSEPORT, all of the servers that later bind to that port must have an effective user ID that matches the effective user ID used to perform the first bind on the socket.
SO_REUSEPORT can be used with both TCP and UDP sockets. With TCP sockets, it allows multiple listening sockets—normally each in a different thread—to be bound to the same port. Each thread can then accept incoming connections on the port by calling accept(). This presents an alternative to the traditional approaches used by multithreaded servers that accept incoming connections on a single socket.
But this seems like a fairly esoteric thing to do.
On Jul 14, 2016, at 1:02 PM, Mark Rivers <[email protected]> wrote:
Why is bind() not returning EADDRINUSE the second time it is called on the same port on Centos6?  Is there some socket option that allows multiple processes to bind to the same port?
Eric Norum
[email protected]
RE: Problem with procServ on RHEL6 Mark Rivers
Prev: RE: Problem with procServ on RHEL6 Mark Rivers
Next: RE: Problem with procServ on RHEL6 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
