1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM installation error on Linux Mint (libXp.a error)
To: [email protected]
Date: Sun, 24 Jul 2016 19:55:32 +0300
It is SOLVED..
I take the "libXp.a" file on Ubuntu 16.04 and copy that to the Linux Mint "/usr/lib/x86_64-linux-gnu" path. And the problem is solved.
I don't know why that doesn't work in Linux Mint, but if someone has this problem, this may help..
Best Regards..
Hulusi
2016-07-24 18:28 GMT+03:00 Hulusi Öz <[email protected]>:
Hi Everyone,
I have already installed Epics_Base, Medm, and some other libraries on my other computer which is Ubuntu 16.04.
For Linux Mint Mate 18, I installed base,extension package, but for MEDM, I couldn't do that.
I have changed the extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 .
I installed the libraries except libxp-dev. When I try to install this library,it says there are others libraries which refers to that. ( In Ubuntu, I couldn't also install that library). Then, I installed "libxpm-dev" and "libxmu-dev" . In Ubuntu, MEDM worked fine, but in Linux Mint, it doesn't work.
It keeps saying "libXp.a" error :
make -C ./printUtils install
make[1]: Entering directory '/opt/epics/extensions/src/medm3_1_9/printUtils'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. T_A=linux-x86_64 install
make[2]: Entering directory '/opt/epics/extensions/src/medm3_1_9/printUtils/O.linux-x86_64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/opt/epics/extensions/src/medm3_1_9/printUtils/O.linux-x86_64'
make[1]: Leaving directory '/opt/epics/extensions/src/medm3_1_9/printUtils'
make -C ./xc install
make[1]: Entering directory '/opt/epics/extensions/src/medm3_1_9/xc'
make[2]: Entering directory '/opt/epics/extensions/src/medm3_1_9/xc/O.linux-x86_64'
make[2]: Leaving directory '/opt/epics/extensions/src/medm3_1_9/xc/O.linux-x86_64'
make[1]: Leaving directory '/opt/epics/extensions/src/medm3_1_9/xc'
make -C ./medm install
make[1]: Entering directory '/opt/epics/extensions/src/medm3_1_9/medm'
make[2]: Entering directory '/opt/epics/extensions/src/medm3_1_9/medm/O.linux-x86_64'
make[2]: *** No rule to make target '/usr/lib/x86_64-linux-gnu/libXp.a', needed by 'medm'.  Stop.
make[2]: Leaving directory '/opt/epics/extensions/src/medm3_1_9/medm/O.linux-x86_64'
../../../../base/configure/RULES_ARCHS:63: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/opt/epics/extensions/src/medm3_1_9/medm'
../../../base/configure/RULES_DIRS:70: recipe for target 'medm.install' failed
make: *** [medm.install] Error 2
Thanks in advance..
Best Regards..
Hulusi
Re: MEDM installation error on Linux Mint (libXp.a error) Michael Westfall
MEDM installation error on Linux Mint (libXp.a error) Hulusi Öz
Prev: MEDM installation error on Linux Mint (libXp.a error) Hulusi Öz
Next: Can I start a pcaspy ioc together with a streamdevice ioc Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MEDM installation error on Linux Mint (libXp.a error) Michael Westfall
ANJ, 25 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
