1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS-Arduino Serial Communication via Asyn-Stream Drivers
To: Mark Rivers <[email protected]>, [email protected]
Date: Mon, 25 Jul 2016 22:58:06 +0300
How can i solve that problem ? Can I re-configure it with EPICS functionally ?
Yes, I want to talk a real hardware. But, since I am new at this area, I thought, if I can do database stuff with arduino in terms of serial communication, I may handle with a real hardware.
I don't know what the things requires for Caen digitizier, the things may change from hardware to hardware. I mean, talking to arduino and Caen digitizer may not be the same stuff. But, I've just started at some point.
Best Regards..
2016-07-25 22:51 GMT+03:00 Mark Rivers <[email protected]>:
The files arduino.db and /opt/epics/helloWorld/db/helloWorldIOC.db are some local files that were specific to the application in that Web page you found.  They don’t come with EPICS base.
What is it you would like to try before beginning to work with the Caen digitizer?  Talking to real hardware?
From: [email protected] [mailto:[email protected]] On Behalf Of Hulusi Öz
Sent: Monday, July 25, 2016 2:44 PM
To: [email protected]
Subject: EPICS-Arduino Serial Communication via Asyn-Stream Drivers
Hi Everyone,
I have just been dealing with EPICS and its applications since a few weeks. I've done basic things such as creating IOC, making MEDM display,communicating Octave and etc..And I've got help most of the time in this tech-talk.
I am now dealing with communication a device that is supported by EPICS. I have got a Digitizier which is manufactured by CAEN. But before I deal with that device, I want to figure out the database configuration in an application. Therefore, I research on the Internet and in this website. I found a quite basic example which is :
I've just done the previous sections of this example,and also followed the steps in that link. However, when I run it I've got nothing.
More specifically :
#!/opt/epics/helloWorldIOC/bin/linux-x86_64/helloWorldIOC
## You may have to change helloWorldIOC to something else
## everywhere it appears in this file
#< envPaths
epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db")
dbLoadDatabase("../../dbd/helloWorldIOC.dbd",0,0)
helloWorldIOC_registerRecordDeviceDriver(pdbbase)
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyACM0",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","115200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","none")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
dbLoadRecords("db/arduino.db","PORT='SERIALPORT'")
filename="../dbLexRoutines.c" line number=240
No such file or directory dbRead opening file db/arduino.db
## Load record instances
dbLoadRecords("/opt/epics/helloWorld/db/helloWorldIOC.db","user=hulusi")
No such file or directory dbRead opening file /opt/epics/helloWorld/db/helloWorldIOC.db
iocInit()
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Jul 21 2016
## Start any sequence programs
#seq snchelloWorldIOC,"user=hulusi"
I guess, the problem is due to the colored line in this output. But I'm not sure that.
Is it so ? If it is like that, how can I figure it out ?
If it isn't like that, what does the thing cause this problem ?
Thanks in advance..
Best regards..
Hulusi
RE: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Jemian, Pete R.
RE: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Mark Rivers
EPICS-Arduino Serial Communication via Asyn-Stream Drivers Hulusi Öz
Prev: RE: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Mark Rivers
Next: RE: EPICS-Arduino Serial Communication via Asyn-Stream Drivers Jemian, Pete R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 25 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
