1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Inconsistency in devAsynOctet for stringout and waveform records
To: "'Andrew Johnson'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jul 2016 14:42:14 +0000
Hi Andrew,
That's probably a good idea, since that is what it does for the stringout record, and we are trying to make them behave the same.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Tuesday, July 26, 2016 9:40 AM
To: [email protected]
Subject: Re: Inconsistency in devAsynOctet for stringout and waveform records
Hi Mark,
On 07/25/2016 09:32 PM, Mark Rivers wrote:
> When waveform records are being used for strings the null is removed
> in drivers because the length they are passed with asynOctetWrite
> does not include the null.  The length passed is NORD-1 if
> VAL[NORD-1] is 0.
If the waveform support is now intended explicitly for writing strings,
should it do an strlen() on the buffer and just send the characters
before first zero, which might appear even before VAL[NORD-1]?
Just a thought...
- Andrew
Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Re: Inconsistency in devAsynOctet for stringout and waveform records Eric Norum
RE: Inconsistency in devAsynOctet for stringout and waveform records Mark Rivers
Re: Inconsistency in devAsynOctet for stringout and waveform records Torsten Bögershausen
Re: Inconsistency in devAsynOctet for stringout and waveform records Andrew Johnson
Prev: Re: Inconsistency in devAsynOctet for stringout and waveform records Andrew Johnson
Next: streamdevice question geyang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Inconsistency in devAsynOctet for stringout and waveform records Torsten Bögershausen
ANJ, 26 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
