In my areaDetector plugin I'm calling this method in one of two
ways, depending on a PV value:
- With pData pointing to a memory buffer that I've allocated and
manage myself;
- With pData null
All seems to work well when operated continuously in either mode,
but I see a crash in RtlFreeHeap when I process at least one frame
in the first mode, and then switch to the second. This does not
happen if I perform the same sequence of steps but instead of
passing the pData to my buffer, I pass null and then copy from my
buffer to the output - but this is a large buffer so I'd like to
avoid this.
I haven't found anything in the documentation that says as much
but I had assumed that, if I pass my own buffer to alloc,
NDArrayPool would regard me as its owner and would never try to
deallocate it. (I would also expect it to exclude my buffer's
size from its allocation limit calculations, but that's a
secondary concern). However, that appears not to be the case:
NDArrayPool::alloc is deciding to free a now-unused NDArray that's
pointing to my buffer and so it's calling
free(freeArray->pData); that's failing because the memory was
allocated in a manner incompatible with free. NDArray seems to
contain nothing that indicates who allocated the buffer, so
NDArrayPool cannot reasonably alter its behaviour accordingly.
This behaviour doesn't seem right to me (on general principles) -
but maybe I've misunderstood how I'm supposed to use this API?
Phil
Pixel
Analytics is a limited company registered in England.
Company number: 7747526; Registered office: 93A New Road,
Haslingfield, Cambridge CB23 1LP
- RE: NDArrayPool::alloc failing Mark Rivers
Re: EpicsQT and Archiver Appliance Michael Davidsaver
Re: may I start a pcaspy ioc together with a streamdevice ioc? Rod Nussbaumer
<2016>
2025
2026
Re: Epics-Digitizer Communication Hulusi Öz
<2016>
2025
2026
ANJ, 09 Aug 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
