1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compile error in ADExample/simDetector with opencv
To: Alireza Panna <[email protected]>
Date: Thu, 4 Aug 2016 01:11:13 +0000
By dynamic I mean that you are building windows-x64 rather than windows-x64-static.  By default that is a dynamic (using dlls) build.
Sent from my iPhone
On Aug 3, 2016, at 5:17 PM, Alireza Panna <[email protected]<mailto:[email protected]>> wrote:
Hi Mark,
Thanks for the quick reply. I added this in the commonLibraryMakefile:
ifdef ADPLUGINEDGE
  ifdef OPENCV_LIB
    opencv_core_DIR     += $(OPENCV_LIB)
    LIB_LIBS           += opencv_world310
  else
    LIB_SYS_LIBS       += opencv_world310
  endif
endif
now in the commonDriverMakefile, i just have the following:
ifdef ADPLUGINEDGE
  PROD_LIBS             += NDPluginEdge
  $(PROD_NAME)_DBD      += NDPluginEdge.dbd
endif
I get the following error now after doing make realclean realuninstall && make
NDPluginEdge.lib(NDPluginEdge.obj) : error LNK2001: unresolved external symbol "
void __cdecl cv::blur(class cv::_InputArray const &,class cv::_OutputArray const
 &,class cv::Size_<int>,class cv::Point_<int>,int)" (?blur@cv@@YAXAEBV_InputArra
y@1@AEBV_OutputArray@1@V?$Size_@H@1@V?$Point_@H@1@H@Z)
void __cdecl cv::fastFree(void *)" (?fastFree@cv@@YAXPEAX@Z)
public: void __cdecl cv::Mat::deallocate(void)" (?deallocate@Mat@cv@@QEAAXXZ)
public: void __cdecl cv::Mat::create(int,int const *,int)" (?create@Mat@cv@@QEAA
XHPEBHH@Z)
void __cdecl cv::Canny(class cv::_InputArray const &,class cv::_OutputArray cons
t &,double,double,int,bool)" (?Canny@cv@@YAXAEBV_InputArray@1@AEBV_OutputArray@1
@NNH_N@Z)
ADCSimDetectorApp.exe : fatal error LNK1120: 5 unresolved externals
make[6]: *** [ADCSimDetectorApp.exe] Error 1120
make[6]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/ADC
SimDetectorIOC/ADCSimDetectorApp/src/O.windows-x64'
make[5]: *** [install.windows-x64] Error 2
make[5]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/ADC
SimDetectorIOC/ADCSimDetectorApp/src'
make[4]: *** [src.install] Error 2
make[4]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/ADC
SimDetectorIOC/ADCSimDetectorApp'
make[3]: *** [ADCSimDetectorApp.install] Error 2
make[3]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/ADC
SimDetectorIOC'
make[2]: *** [ADCSimDetectorIOC.install] Error 2
make[2]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs'
make[1]: *** [iocs.install] Error 2
make[1]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample'
make: *** [C:\Epics\support\areaDetector-2-4/ADExample.install] Error 2
I then switched to staticlib for opencv. My config_site.local now looks like this:
OPENCV          = C:/opencv-2.4.13
OPENCV_LIB      = $(OPENCV)/build/x64/vc12/staticlib
OPENCV_INCLUDE  = -I$(OPENCV)/build/include/
​and the commonDriverMakefile:
​ifdef ADPLUGINEDGE
  ifdef OPENCV_LIB
    PROD_LIBS           += opencv_core2413 opencv_imgproc2413
  else
    PROD_SYS_LIBS       += opencv_core2413 opencv_imgproc2413
  endif
endif
In this case I still get a similar error as before.
make[6]: *** No rule to make target `../../../lib/windows-x64/opencv_core2413.li<http://opencv_core2413.li>
b', needed by `simDetectorNoIOCApp.exe'.  Stop.​
When you say building dynamic I assume you mean the opencv libs I am using are built dynamic, i build epics base as static.
Thanks
Ali
On Wed, Aug 3, 2016 at 3:04 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Because you are building dynamically you also need to define LIB_LIBS the same way you defined PROD_LIBS.
If this works you could make a pull request for the fix.
Sent from my iPhone
On Aug 3, 2016, at 2:06 PM, Alireza Panna <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
I am trying to use ADPluginEdge with the sim detector and I run into the following error:
make[6]: Entering directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/si
mDetectorNoIOC/simDetectorNoIOCApp/src/O.windows-x64'
cl /nologo /EHsc /GR -c              /favor:blend   /nologo /D__STDC__=0 /D_CRT_
SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355     -DH5
_BUILT_AS_STATIC_LIB    /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I.. -I.
.\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include  -I..\\..\\..\\..\\..\\inclu
de     -IC:\Epics\base-3.14.12.5\\include\\os\\WIN32 -IC:\Epics\base-3.14.12.5\\
include  -IC:\Epics\support\\asyn-4-29\\include -IC:\Epics\support\areaDetector-
2-5\\ADBinaries\\include\\os\\WIN32 -IC:\Epics\support\areaDetector-2-4\\ADBinar
ies\\include -IC:\Epics\support\areaDetector-2-4\\ADCore\\include\\os\\WIN32 -IC
:\Epics\support\areaDetector-2-4\\ADCore\\include -IC:\Epics\support\\autosave-5
-7-1\\include\\os\\WIN32 -IC:\Epics\support\\autosave-5-7-1\\include  -IC:\Epics
\support\\busy-1-6-1\\include  -IC:\Epics\support\\calc-3-2\\include  -IC:\Epics
\support\\seq-2-1-18\\include  -IC:\Epics\support\\sscan-2-10-1\\include -IC:\Ep
ics\support\\devIocStats-3-1-14\\include\\os\\WIN32 -IC:\Epics\support\\devIocSt
ats-3-1-14\\include  -IC:\Epics\support\\caPutLog-3-4\\include       -I\\usr\\lo
cal64\\include  -I\\usr\\include\\libxml2    ..\\simDetectorNoIOC.cpp
make[6]: *** No rule to make target `../../../lib/windows-x64/opencv_world310.li<http://opencv_world310.li><http://opencv_world310.li>
make[6]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim
make[5]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim
DetectorNoIOC/simDetectorNoIOCApp/src'
make[4]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim
DetectorNoIOC/simDetectorNoIOCApp'
make[3]: *** [simDetectorNoIOCApp.install] Error 2
make[3]: Leaving directory `C:/Epics/support/areaDetector-2-4/ADExample/iocs/sim
DetectorNoIOC'
make[2]: *** [simDetectorNoIOC.install] Error 2
To get it to compile and the plugin to work with the simDetector, I am manually copying the opencv_world310.lib file in the $(ADExample)/lib/$(EPICS_HOST_ARCH) directory.
my CONFIG_SITE.local has opencv location defined as:
OPENCV          = C:/opencv-3.1
OPENCV_LIB      = $(OPENCV)/build/x64/vc12/lib
and the commonDriverMakefile has the following defined:
ifdef ADPLUGINEDGE
  ifdef OPENCV_LIB
    PROD_LIBS           += opencv_world310
  else
    PROD_SYS_LIBS       += opencv_world310
  endif
endif
Is there something else I need to add/change to get it to compile properly?
Thanks
Best,
Ali
Re: compile error in ADExample/simDetector with opencv Alireza Panna
Re: compile error in ADExample/simDetector with opencv Mark Rivers
Prev: EPICS support for SAES NEXTorr NEG & SIP Power Controllers Saraf, Shweta
Next: Re: compile error in ADExample/simDetector with opencv Alireza Panna
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: compile error in ADExample/simDetector with opencv Alireza Panna
ANJ, 03 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
