1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compile Matlab CA client on 64bit Windows 7?
To: "Kasemir, Kay" <[email protected]>
Cc: "Jeffrey J. Hagen, Ph.D." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 4 Aug 2016 17:57:20 +0200
Hi Kay,
I've managed to go over this exercise the other day. I had most problems in getting the development environment set up on my side, otherwise it is smooth sailing.
Cheers,
Hinko
On Thu, Aug 4, 2016 at 3:06 PM, Kasemir, Kay <[email protected]> wrote:
Hello:
Has anybody successfully tried to build the Matlab CA client on 64bit Windows 7?
I’m referring to the ‘MCA’ package, https://github.com/EPICSTools/mca .
The last information related to Windows is in the README_WIN32, and no longer applies to a more recent version of Matlab and MS Visual Studio.
Kay
.. the more I see the less I believe.., AE AoR
MCA on windows 7, 64-bit
Download and install 7zip (http://www.7-zip.org/download.html)
Download and install Make (http://gnuwin32.sourceforge.net/packages/make.htm)
Download and install Perl (http://strawberryperl.com/)
Install Matlab 2016a (if not already installed)
Download and install Microsoft Windows SDK v7.1
 http://se.mathworks.com/matlabcentral/answers/101105-how-do-i-install-microsoft-windows-sdk-7-1?requestedDomain=www.mathworks.com
 https://www.microsoft.com/en-us/download/details.aspx?id=8279 -  Microsoft Windows SDK for Windows 7 and .NET Framework 4
 If it complains about .NET 4 missing, follow the instructions on first link.
 I did not reinstall .NET 4.5 after installing SDK v7.1, that I had to remove in my case.
Compile EPICS base 3.14.12.5
 Get the sources
  http://www.aps.anl.gov/epics/download/base/baseR3.14.12.5.tar.gz
 Extract to c:\
 Set EPICS_HOST_ARCH in Environment Variables, System Variables to
  EPICS_HOST_ARCH=windows-x64
 Open cmd
 Setup 64-bit compiler (see http://stackoverflow.com/questions/20829477/vcvars64-bat-file-is-missing)
 No vcvarsall.bat et. al. needed, just run following command
  CALL "c:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.Cmd" /x64
 cmd text turns yellow
 Check compiler version that it shows "x64"
  cl \h
Microsoft (R) C/C++ Optimizing Compiler Version 16.00.30319.01 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
Adjust LINK_OPT_FLAGS_YES in  base-3.14.12.5\configure\os\CONFIG.win32-x86.win32-x86
 Look for "LINK_OPT_FLAGS_YES" and add "/MANIFEST"
 New content: LINK_OPT_FLAGS_YES = /MANIFEST /LTCG /incremental:no /opt:ref /release $(PROD_VERSION:%=/version:%)
 Compile EPICS base
  cd c:\base-3.14.12.5
  "c:\Program Files (x86)\GnuWin32\bin\make.exe"
Download and compile MCA sources (https://ics-web.sns.ornl.gov/kasemir/mca/index.html)
 At this time R4-4 is latest stable
 Extract to Matlab toolbox folder
Setup MEX C compiler
 mex -setup -v
Found installed compiler 'Microsoft Windows SDK 7.1 (C)'.
MEX configured to use 'Microsoft Windows SDK 7.1 (C)' for C language compilation.
Setup MEX C++ compiler
 mex -setup -v c++
Found installed compiler 'Microsoft Windows SDK 7.1 (C++)'.
MEX configured to use 'Microsoft Windows SDK 7.1 (C++)' for C++ language compilation.
Compile MCA
 Make sure that -DEPICS_NO_DLL is *NOT* specified! Otherwise linking fails due
 to some missing symbols!
 cd c:\MATLAB\R2016a\toolbox\mca-R4-4
 mex mca.cpp MCAError.cpp Channel.cpp c:\base-3.14.12.5\lib\windows-x64\Com.lib c:\base-3.14.12.5\lib\windows-x64\ca.lib -DDB_TEXT_GLBLSOURCE -DMSCC -DWIN32 -DWIN64 -Ic:\base-3.14.12.5\include -Ic:\base-3.14.12.5\include\os\WIN32 -v
 Should have 'mca.mexw64' if all goes well!
Setup PATH in Environment Variables, System Variables to hold EPICS paths
... ;C:\base-3.14.12.5\bin\windows-x64;C:\base-3.14.12.5\lib\windows-x64
Start matlab
Add paths to MCA
>> addpath c:\MATLAB\R2016a\toolbox\mca-R4-4
>> addpath c:\MATLAB\R2016a\toolbox\mca-R4-4\matlab
Get PV value
>> pv=mcaopen('LLRF:OPMODE')
MCA Initialized
pv =
     1
>> mcaget(pv)
ans =
     4
DONE!
Attachment: Screenshot_2016-06-17_10-28-38.png
Description: PNG image
Compile Matlab CA client on 64bit Windows 7? Kasemir, Kay
Prev: Compile Matlab CA client on 64bit Windows 7? Kasemir, Kay
Next: [no subject] Paramveer Jain
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 05 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
