Hi All,
I've built device support for ai record for a vme based ADC board. I've used the following to add the support: device(ai,VME_IO, devAiADCtype1, "HW Channel"); where devAiADCtype1 is the structure in the device support routine. The things are working fine. When I insert an ai record, I get a DTYP as 'HW Channel' , I pass on the relevant VME_IO address ant the board gets read. Now I want to build device support for ai record to support one more type of vme based ADC board to be used in the same system. How do I do it ? Should I write something like : device(ai,VME_IO, devAiADCtype2, "HW Channel 2"); or is there another method of doing so ? I mean how make multiple device support for a given record type ? Please suggest, Thanks, Stefen
| ANJ, 12 Aug 2016 |
Home
News
About
Talk
Base
Modules
Extensions
