1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: building EPICS base-13.15.4 on Windows 10
To: "Lee, William R. (LARC-D304)[Jacobs Technology, Inc.]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 11 Aug 2016 17:13:16 -0500
Hi Bill,
On 08/10/2016 06:22 PM, Lee, William R. (LARC-D304)[Jacobs Technology,
Inc.] wrote:
> I am trying to build EPICS base-3.15.4 on Windows 10 (64-bit) using
> Visual Studio 10. The build fails with the following messages:
> make[3]: *** No rule to make target '../../../lib/windows-x64/Com',
> needed by 'iocLogServer.exe'.  Stop.
This is strange; normally at that point in the build process instead of
iocLogServer.c the source files that make up the libCom library
(Com.dll) get compiled, and then the library itself is constructed. You
can see that in the output from the Jenkins build job at
https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/256/consoleFull
> I've included artifacts below which I hope will be helpful in diagnosing
> my problem(s):
They were helpful, thanks.
Is it possible that your initial 'make clean uninstall' did not actually
cause an older bin/windows-x64/Com.dll file to be deleted?
If caRepeater.exe is still running in the background, the libraries it
depends on cannot be removed, and this might have the effect you're
seeing. I usually use 'make distclean' instead, which fails when it
can't delete the non-empty bin/ directory, but I'm not sure whether the
uninstall target will fail in the same way or not.
I can't think of any other explanation at this point, please write back
to tech-talk if this doesn't help though as others here may have more ideas.
- Andrew
RE: building EPICS base-13.15.4 on Windows 10 Lee, William R. (LARC-D304)[Jacobs Technology, Inc.]
Prev: Re: Race condition in db_get_field_and_count() (3.14.12) Andrew Johnson
Next: Re: Race condition in db_get_field_and_count() (3.14.12) Williams Jr., Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: building EPICS base-13.15.4 on Windows 10 Lee, William R. (LARC-D304)[Jacobs Technology, Inc.]
Next: RE: building EPICS base-13.15.4 on Windows 10 Lee, William R. (LARC-D304)[Jacobs Technology, Inc.]
ANJ, 12 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
