1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is it possible for channel access to send duplicates?
To: Michael Davidsaver <[email protected]>
Date: Fri, 12 Aug 2016 20:06:12 +0000
Hi:
> On 08/12/2016 03:48 PM, Zhang, Dehong wrote:
>> Is it possible that the channel access server may send duplicates,
>> or re-transmit the same messages?  Specially when congested?
Not sure what level this question addresses.
Assuming the question is:
If you run “camonitor some_PV_name”, will you see the same message over and over?
I.e. same time stamp, same value?
-> That should not happen.
The record will only send an update when the value changes.
Unless you have an analog record with MDEL = -1, in which case you’ll see a message whenever the record processes, even if the value remains the same. The time stamp would still differ, though.
If you have MDEL=-1, and your timing configuration is broken, i.e. your IOC is configured to get the time from somewhere, and that keeps sending the same time of day, then yes, you might see the same value with the same time stamp.
-Kay
Is it possible for channel access to send duplicates? Zhang, Dehong
Re: Is it possible for channel access to send duplicates? Michael Davidsaver
Prev: Re: Is it possible for channel access to send duplicates? Michael Davidsaver
Next: Re: Is it possible for channel access to send duplicates? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
