1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about data display in css boy opi databrowser
To: lzf neu <[email protected]>
Date: Mon, 15 Aug 2016 12:56:19 +0000
Hi:
On Aug 13, 2016, at 8:24 AM, lzf neu <[email protected]> wrote:
> There are six pv data and I want to display the selected pv data in databrowser by clicking the Check Box widget. I don't know how to make the settings or write script in details in css boy opi or any other methods to cope with this problem.
Ideally, avoid scripts, and do all the processing on the IOC.
Especially when you don’t know how to use scripts, it’s better to avoid them.
If you have several records and you want to select one of them, check the select (“sel”) record, http://www.aps.anl.gov/epics/EpicsDocumentation/AppDevManuals/RecordRef/Recordref-33.html
Somewhat like this:
# PV Shown in a combo box that allows selecting one of the 6 sources
record(mbbi, “choose_one”)
  field(ZRVL, “0”)
  field(ZRST, “Option A”)
  field(ONVL, “1”)
  field(ONST, “Option B”)
# Record that will hold the value of one of the six data PVs.
# Simply display this record in the user interface
record(sel, “active_value”)
  field(SELM, “Specified”)
  field(NVL, “ choose_one”)
  field(INPA, “record_for_option_A”)
  field(INPB, “record_for_option_A”)
Add FLNK or CP or .. do trigger processing as desired.
-Kay
Question about data display in css boy opi databrowser lzf neu
Prev: RE: synApps 5.8 build issue Mooney, Tim M.
Next: Re: Drawing on XY graph widget without the use of a PV in CSS Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Question about data display in css boy opi databrowser lzf neu
Next: synApps 5.8 build issue Abdalla Ahmad
ANJ, 15 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
