1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Alias
To: Stefen Paul <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 17 Aug 2016 11:40:15 +0000
> I tried using the command alias("canonicalName","aliasName") in my code.
> I also wrote #include <dbStaticLib.h> in the code.
> But when I make my application, I get the following error:
> "unresolved external symbol _alias"
The alias command is used in a database file, not in C code.
This is from the Application Developer's Guide:
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide.pdf
Page 107:
6.14 record – Record Instance
  6.14.1 Format
    record(record_type, record_name) {
      alias(alias_name)
      field(field_name, "field_value")
      info(info_name, "info_value")
    alias(record_name, alias_name)
If you want to create an alias in C then you must use this function (page 207)
long dbCreateAlias(DBENTRY *pdbentry, const char *paliasName);
From: [email protected] [[email protected]] on behalf of Stefen Paul [[email protected]]
Sent: Tuesday, August 16, 2016 11:59 PM
To: EPICS Tech Talk
Subject: Alias
Hi All,
I am using EPICS Base version 3.14.12.4
I read that from EPICS 3.14.11 support for alias has been added.
Am I missing something here ?
Stefen
Re: Alias Stefen Paul
Alias Stefen Paul
Prev: Support for Ametek 7270 lock-in amp edmund.warrick
Next: Re: Alias Márcio Paduan Donadio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Alias Stefen Paul
Next: Re: Alias Stefen Paul
ANJ, 19 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
