1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: A Problem while Installing calc in synApps_5_5
To: [email protected]
Date: Wed, 24 Aug 2016 13:23:03 +0900
Hello, This is Jung who is a Epics beginner.
I installed epics R3.16.0.1, Extensions Top (R3.14) and so on.
here is a problem. when I install sysApps_5_8, I received this error.
make -C /usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1 install
make[1]: Entering directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1'
make -C ./configure install
make[2]: Entering directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[3]: Entering directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/configure/O.linux-x86_64'
perl -CSD /usr/local/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[3]: Leaving directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/configure/O.linux-x86_64'
make[2]: Leaving directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/configure'
make -C ./calcApp install
make[2]: Entering directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp'
make -C ./src install
make[3]: Entering directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[4]: Entering directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp/src/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/usr/local/epics/extensions/src/synApps_5_8/support/sscan-2-10-1/include   -I/usr/local/epics/extensions/src/synApps_5_8/support/seq-2-2-1/include -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include        -c ../sseqRecord.c
../sseqRecord.c: In function ‘putCallbackCB’:
../sseqRecord.c:536:42: error: ‘struct pv_link’ has no member named ‘precord’
  pR = (sseqRecord *)(plink->value.pv_link.precord);
../sseqRecord.c: In function ‘processCallback’:
../sseqRecord.c:604:18: warning: variable ‘did_putCallback’ set but not used [-Wunused-but-set-variable]
  int     status, did_putCallback=0;
/usr/local/epics/base/configure/RULES_BUILD:220: recipe for target 'sseqRecord.o' failed
make[4]: *** [sseqRecord.o] Error 1
make[4]: Leaving directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp/src/O.linux-x86_64'
/usr/local/epics/base/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp/src'
/usr/local/epics/base/configure/RULES_DIRS:88: recipe for target 'src.install' failed
make[2]: *** [src.install] Error 2
make[2]: Leaving directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1/calcApp'
/usr/local/epics/base/configure/RULES_DIRS:88: recipe for target 'calcApp.install' failed
make[1]: *** [calcApp.install] Error 2
make[1]: Leaving directory '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1'
/usr/local/epics/base/configure/RULES_DIRS:88: recipe for target '/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1.install' failed
make: *** [/usr/local/epics/extensions/src/synApps_5_8/support/calc-R3-6-1.install] Error 2
I guess calc of apps has a problem.
PLEASE help me, How can I do..?
Best regards
Pilkyu Jung
RE: A Problem while Installing calc in synApps_5_5 Mooney, Tim M.
Prev: A Problem while Installing calc in synApps_5_5 정필규
Next: RE: A Problem while Installing calc in synApps_5_5 Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
