1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OS X edm/medm openmotif woes
To: Eric Norum <[email protected]>
Date: Thu, 25 Aug 2016 20:45:44 -0500
Well, the only thing I think I did was this:
In CONFIG_SITE.darwin-x86.darwin-x86,
# Homebrew OpenMotif
MOTIF_LIB=/usr/local/lib
MOTIF_INC=/usr/local/include
Then, I thought everything worked…   At least that’s my recollection.
On my previous MacBook Pro (retired in January 2016), when I did El Capitan upgrade, it broke MEDM.  Until then, I was using MacPorts, but decided to switch to HomeBrew.  I will check what I did on that machine later.  Perhaps, there are some hints there…  I also have a few machines that I can test (machines with HomeBrew but no MEDM installed).  I will do so probably tomorrow.
On Aug 25, 2016, at 7:15 PM, Eric Norum <[email protected]> wrote:
Glad to hear that there’s some hope.  Can you please mail me the configuration makefile fragments you used to build?
On Aug 25, 2016, at 4:44 PM, Jiro Fujita <[email protected]> wrote:
That’s strange… I’m running OpenMotif 2.3.4 via HomeBrew with MEDM without any problem on my Mac.  As I recall, all I had to do was to install OpenMotif (and any other things I needed for MEDM).  I’m running on El Capitan, if that makes any difference.  As far as I can tell anything I can make MEDM do, so far, it has been working fine…
I will check, however, if there is any hints to your problem, at least with respect to MEDM.
Eric Norum
[email protected]
Re: OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Jiro Fujita
Prev: EPICS driver for Mitsubishi FX3G PLC Kyle Lanclos
Next: asyn R4-30 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OS X edm/medm openmotif woes Eric Norum
Next: Re: OS X edm/medm openmotif woes Eric Norum
ANJ, 26 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
