On 29/08/2016 15:03, Mark Rivers wrote:
Doesn’t matter, the easiest way to configure this is still to leave EPICS_CAS_SERVER_PORT undefined
since the clients will find all your IOCs just fine.
The only exception to this is if your clients are on a different subnet from your IOC. In that case I believe you can use a PV gateway, or set the PCAS server port manually and set EPICS_CA_ADDR_LIST on the client.
Or use the iptables trick documented on the user Wiki:
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
Cheers,
~Ralph
- question about pcaspy geyang
- Re: question about pcaspy Kasemir, Kay
- RE: question about pcaspy Mark Rivers
Re: 回复: Re: question about pcaspy Wang Xiaoqiang
<2016>
2025
2026
A problem while execute MEDM3_1_9 정필규
<2016>
2025
2026
