1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OSI error messages with VxWorks 6.9.4.1
To: EPICS <[email protected]>
Date: Mon, 29 Aug 2016 15:32:13 -0500
Since this problem recently arose again and I failed to document it when it was originally resolved, I am responding to my own message from two years ago.
The error messages below are caused by a mismatch between the running version of VxWorks and the tool chain used to build EPICSbase. For example, build EPICSbase using a VxWorks 6.9.3 toolchain and then load it into a VME crate running VxWorks 6.9.4.1 and you will get the error messages below. The reverse also fails; build EPICSbase under 6.9.4.1 and try running it under VxWorks 6.9.3; same errors messages.
The root cause of this problem is that Intel Wind River Systems made changes to some data structures (the specifics of which I no longer recall) that EPICS uses between VxWorks 6.9.3 and 6.9.4.1. Binary compatibility is apparently not guaranteed between "maintenance" versions of VxWorks.
Ron
On 8/25/2014 2:41 PM, Ron Sluiter wrote:
We recently tested VxWorks 6.9.4.1 for the 1st time on a teststand and found some new EPICS error messages that we have not seen before.
osiSockDiscoverBroadcastAddresses(): status: 0x08x, ifconf.ifc_len: -1
osiSockDiscoverBroadcastAddresses(): unable to fetch network interface configuration
and,
osiLocalAddr(): SIOCGIFCONF ioctl failed because "S_errno_ENXIO"
These error messages appeared only once after iocInit and had no discernible effect on IOC performance. We are using base-3.14.12.3.
Is anyone else using VxWorks 6.9.4.1?
Are other VxWorks 6.9.4.1 users seeing these error messages?
Ron
Prev: Re: 回复: Re: question about pcaspy Wang Xiaoqiang
Next: HOW to start working with EPICS Paramveer Jain
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Epics for Phoenix Contact ILC 150 ETH New User
ANJ, 30 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
