1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: macro value
To: l123173 <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 31 Aug 2016 15:19:23 +0000
Hi Li,
How are you supplying macro values to 4motor_form.opi?  You probably want to call up 4motor_form.opi from a related display button.  (That's what the button type is called in MEDM, anyway.  I forget what it's called in BOY.)
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of l123173 [[email protected]]
Sent: Wednesday, August 31, 2016 8:17 AM
To: [email protected]
Subject: macro value
Hi all,
      After I started the IOC and 4motor_form.opi ( ${MOTOR}/motorApp/op/opi ) in CSS, the pv contain "$(P)$(M) ,$(P)$(M1), $(P)$(M2)" all disconnetcted.
      But IOC start up successfully.  And when I changed the pv name to IOC:m2, it connected.
      why does other contain $(P)$(M) disconnected.
dbl list was like these:
epics> dbl
IOC:4
IOC:m2
IOC:m3
IOC:m4
KOZ:m1
the st.cmd file was ( part of st.cmd file):
dbLoadDatabase("$(TOP)/dbd/WithAsyn.dbd")
WithAsyn_registerRecordDeviceDriver(pdbbase)
dbLoadTemplate("motor.substitutions")
drvAsynSerialPortConfigure("serial","/dev/ttyS0",0,0,0)
and the motor.substitutions was:
file "$(MOTOR)/db/basic_motor.db"
pattern
{P,     N,  M,        DTYP,      C,  S,  DESC,          EGU,      DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
{IOC:,  1,  "m$(N)",  "SC-800",  0,  0,  "motor $(N)",  mm,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  2,  "m$(N)",  "SC-800",  0,  1,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  3,  "m$(N)",  "SC-800",  0,  2,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  4,  "m$(N)",  "SC-800",  0,  3,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
Li xing
Re: macro value Pete Jemian
macro value l123173
Prev: macro value l123173
Next: Re: macro value Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Aug 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
