1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Question about determining network connection by using different LED widget color
Date: Thu, 1 Sep 2016 08:21:47 +0000
Hi all,
My problem is to achieve a color change display by using LED widget in css boy opi to determine whether the network communication problem occured.
To achieve this goal, I want to use "ping" command for some ip address ; and If the network communication failed determined by "ping" command then
the LED displays red and "Network communication failed !" in text widget, otherwise the LED color is green.
Maybe this can be done by writing script, but I don't know how to do this in css boy opi or anyother methods to achieve my goal.
Could anyone please help me and thanks in advance !
Zhefu
Re: Question about determining network connection by using different LED widget color Kasemir, Kay
Prev: ether_ip linking issue in epics base-3.15 Kim, Kukhee
Next: Re: Question about determining network connection by using different LED widget color Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ether_ip linking issue in epics base-3.15 Kasemir, Kay
ANJ, 01 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
