1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Programming with caQtDM Framework
To: "Brands Helge (PSI)" <[email protected]>, tech-talk <[email protected]>
Date: Mon, 5 Sep 2016 16:16:34 +0300
Thank you for recommendation sir. It will be really useful for me. In fact, I did the same things by creating .pro files , but I missed some points. I can use these examples as a good guide.
Best regards
Hulusi Oz
2016-09-05 15:44 GMT+03:00 Brands Helge (PSI) <[email protected]>:
Hi Hulusi Öz,
as far I understand you try to make programms with caqtdm. That is not the intention behind a display manager. The work of a
 displaymanager is to interact with the controls system world. In case of caqtdm this is EPICS. If you want to try to programm with caQtDM you can
use the caqtdm_lib part of caqtdm. Anton Mezger made an example (http://epics.web.psi.ch/software/caqtdm/   [3. Howto]).
caqtdm supports calculations (caCalc) EPICS Calc and Perl Regular Expressions and this for visibility. Qt Signals can also be used for Actions.
Best regards
    Helge Brands
AW: Programming with caQtDM Framework Brands Helge (PSI)
Prev: AW: Programming with caQtDM Framework Brands Helge (PSI)
Next: Support for CAEN SY4527 David Brodrick
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 06 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
