1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: motor command in synApp when invoking the drive file
To: [email protected]
Date: Thu, 8 Sep 2016 21:22:25 +0800 (CST)
Hi all,
        I want to control the Kohzu with motor module in synApps.     (fedora23  synApps 5.8   motor6.10   epics 3.15.3)
       Then I started the IOC with the st.cmd.kohzu1 and saw the output with some serial tool in another terminal.
       I got the "IDN?" output when the IOC start, so I think the IOC worked fine.
       But I do not know how to do it then, I do not know how to execute the command "ORG" or other command of Kohzu controller. I don't know how to use the command.
       These command are all exist in KohzuSrc file. Why I could got the IDN command, could not get the other command?
       the dbl list was associated with motor.substitutions.(IOC:m1,IOC:m2,.....,IOC:m8)
       Which step I forgot?
Li xing
st.cmd.kohzu1:
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("TOP","/opt/epics/synApps_5_8/support/motor-6-10")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("STREAM","/opt/epics/synApps_5_8/support/stream-2-6a")
epicsEnvSet("ASYN","/opt/epics/synApps_5_8/support/asyn-4-26")
epicsEnvSet("MOTOR","/opt/epics/synApps_5_8/support/motor-6-10")
# For deviocstats
# Change this PV according to set-up
# Overide default
# Increase size of buffer for error logging from default 1256
errlogInit(20000)
# Register all support components
dbLoadDatabase("$(TOP)/dbd/WithAsyn.dbd")
WithAsyn_registerRecordDeviceDriver(pdbbase)
dbLoadTemplate("motor.substitutions")   #this file in motor/ioc/ioc/ ,the content was in "dbl"
drvAsynSerialPortConfigure("serial","/dev/ttyS0",0,0,0)
asynOctetSetInputEos("serial",0,"\r\n")
asynOctetSetOutputEos("serial",0,"\r\n")
asynSetOption("serial",0,"baud","38400")
asynSetOption("serial",0,"bits","8")
asynSetOption("serial",0,"stop","1")
asynSetOption("serial",0,"parity","none")
asynSetOption("serial",0,"clocal","Y")
asynSetOption("serial",0,"crtscts","N")
asynSetOption("serial",0,"")
asynSetTraceIOMask("serial",0,2)
asynSetTraceMask("serial",0,0xFF)
#GPIB: portname, autoConnect, boardId, timeout, 5th_arg
##GpibBoardDriverConfig("kohzu",1,0,3,0) #comment out
# Kohzu SC-800 motor controller setup parameters:
#     (1) maximum number of controllers in system
#     (2) motor task polling rate (min=1Hz,max=60Hz)
##SC800Setup(5, 60)
SC800Setup(1,1)
# Kohzu SC-800 motor controller configuration parameters:
#     (1) controller# being configured
#     (2) ASYN port name
#     (3) address (GPIB only)
SC800Config(0,"serial",0)
var drvSC800debug 4
# Start EPICS IOC
iocInit
motor.substitutions:
file "$(MOTOR)/db/basic_motor.db"
pattern
{P,     N,  M,        DTYP,      C,  S,  DESC,          EGU,      DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
{IOC:,  1,  "m$(N)",  "SC-800",  0,  0,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  2,  "m$(N)",  "SC-800",  0,  1,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  3,  "m$(N)",  "SC-800",  0,  2,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  4,  "m$(N)",  "SC-800",  0,  3,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  5,  "m$(N)",  "SC-800",  0,  4,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  6,  "m$(N)",  "SC-800",  0,  5,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  7,  "m$(N)",  "SC-800",  0,  6,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
{IOC:,  8,  "m$(N)",  "SC-800",  0,  7,  "motor $(N)",  um,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
Attachment: st.cmd.kohzu1
Description: Binary data
Attachment: motor.substitutions
Prev: Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Benjamin Franksen
Next: Re: Autosave ignores PVs starting with some characters J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VDCT Ralph Lange
Next: motor command in synApps l123173
ANJ, 13 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
