1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Long string command to device
To: [email protected]
Date: Tue, 20 Sep 2016 10:34:18 +0200
I am working on modifying an EPICS interface for a LakeShore 336 (LS336) temperature controller. In that connection I need to send strings to the LS336 which extends 40 characters.
I found the following thread:
http://www.aps.anl.gov/epics/tech-talk/2016/msg00887.php
which discusses a similar problem, and suggests to use waveform records and StreamDevice (which I am already using).
However, I am unable to get this to work.
As I read the documentation of waveform records they are only for input, and hence does not allow to set the OUT field (I am using EPICS 3.14)
Can anyone help with a solution to this problem?
Best
Bo Jakobsen
RE: Long string command to device Mark Rivers
Prev: Re: query Márcio Paduan Donadio
Next: RE: Long string command to device Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: AW: long string command to device Zimoch Dirk (PSI)
ANJ, 20 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
