1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS Boy Write PVs to file
Date: Thu, 22 Sep 2016 13:49:26 +0000
> > Overall, performing logic like data acquisition should not be
> > handled in the user interface.
> There are a couple of use cases that do not require any complex logic.
> For example saving a snapshot of a waveform PV into a file. For many
> use cases it makes more sense to save this file to a client machine.
> Example: Reading/writing firmware via waveform PVs. The FPGA engineer
> might not even have access to the IOC's file system...
Saving a waveform snapshot is exactly what I'm trying to do.
> > Better would be to add a listener to the PV which gets notified as
> > values arrive.
> Sounds reasonable. Can you point us to an example/documentation?
In my case, the values I receive are largely one-offs from an expensive operation, so what considerations would there be?
Thank you,
Iain.
Re: CSS Boy Write PVs to file Konrad, Martin
Prev: RE: CSS Boy Write PVs to file Iain Marcuson
Next: Re: module for Keithley 6485 PA-meter Peter . Mueller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS Boy Write PVs to file Konrad, Martin
Next: [no subject] Paramveer Jain
ANJ, 23 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
