Hi Mark,
Am I right in thinking this should work with NDArrays of different data types or dimensions, at least if the driver or plugin maintained different NDArrayPool instances?
Cheers,
Matt
> On Sep 23, 2016, at 8:04 AM, Mark Rivers <[email protected]> wrote:
> Hi Hinko,
>> To answer my own question, I think the NDPluginTimeSeries::doTimeSeriesCallbacks() does what I'm after.
> Yes, that is correct. Each NDArray callbacks is done with a different asyn "addr". So the plugin must pass the flag ASYN_MULTIDEVICE in the constructor and downstream plugins must subscribe for callbacks using the appropriate "addr".
> This is a search to see what plugins call doCallbacksGenericPointer with a non-zero final argument:
> NDPluginCircularBuff.cpp: doCallbacksGenericPointer(preBuffer_->readFromStart(), NDArrayData, 0);
> NDPluginCircularBuff.cpp: doCallbacksGenericPointer(preBuffer_->readNext(), NDArrayData, 0);
> NDPluginCircularBuff.cpp: doCallbacksGenericPointer(pArrayCpy, NDArrayData, 0);
> NDPluginColorConvert.cpp: doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
> NDPluginFFT.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
> NDPluginFile.cpp: doCallbacksGenericPointer(pArray, NDArrayData, 0);
> NDPluginFile.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
> NDPluginOverlay.cpp: doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
> NDPluginProcess.cpp: doCallbacksGenericPointer( pArrayOut, NDArrayData, 0);
> NDPluginROI.cpp: doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
> NDPluginROIStat.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
> NDPluginStats.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, 0);
> NDPluginTimeSeries.cpp: doCallbacksGenericPointer(pArrayOut, NDArrayData, numSignals_);
> NDPluginTimeSeries.cpp: doCallbacksGenericPointer(pArray, NDArrayData, signal);
> NDPluginTransform.cpp: doCallbacksGenericPointer(transformedArray, NDArrayData,0);
> NDPosPlugin.cpp: doCallbacksGenericPointer(this->pArrays[0], NDArrayData, 0);
> So of the standard plugins in ADCore only NDPluginTimeSeries does this.
> Mark
> ________________________________
> From: [email protected] [[email protected]] on behalf of Hinxx [[email protected]]
> Sent: Friday, September 23, 2016 6:44 AM
> To: [email protected]
> Subject: Re: areaDetector plugin with multiple outputs
> On 09/23/2016 10:41 AM, Hinxx wrote:
> Hi,
> I would like to have a single input array into areaDetector plugin and have the plugin deliver multiple arrays as output. Is this possible? Are there any examples?
> I would then like to feed the output arrays into other areaDetector plugins.
> Thanks,
> Hinko
- RE: areaDetector plugin with multiple outputs Mark Rivers
- areaDetector plugin with multiple outputs Hinxx
- Re: areaDetector plugin with multiple outputs Hinxx
<2016>
2025
2026
<2016>
2025
2026
