1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Andor SDK3 issue - AT_WaitBuffer fails
Cc: "[email protected] list" <[email protected]>
Date: Fri, 23 Sep 2016 13:32:52 +0000
Hi Mark,
I’m linking against the 3.9 SDK that’s installed using the Andor install script in /usr/local/, so it’s possible there is an inconsistency there. I seem to remember trying the 3.10 version when I updated to R2-1, but I’m not sure why I switched back to 3.9.
Since Andor have asked me to update to 3-12 I’ll try that (and fix my build inconsistency).
Cheers,
Matt
> On Sep 23, 2016, at 9:14 AM, Mark Rivers <[email protected]> wrote:
> Hi Matt,
> What version of ADAndor3 are you running?  The latest release is R2-1, which is built with 3.10.3 of the SDK.  You say you are running with 3.9 of the SDK.  You need to make sure the version of the SDK you installed on your system is consistent with the .h and .so files in ADAndor3/andor3Support.
> If you restart the IOC does it start working, or so you need to power-cycle the camera?
> Mark
> From: [email protected] [[email protected]] on behalf of Pearson, Matthew R. [[email protected]]
> Sent: Friday, September 23, 2016 7:54 AM
> To: [email protected] list
> Subject: Andor SDK3 issue - AT_WaitBuffer fails
> Hi,
> We have an Andor sCMOS Zyla camera and we use the Andor3 support in areaDetector. This uses the Andor SDK3 API to control the camera and read out data. Sometimes we see the Andor3 driver get into a state because the:
> status = AT_WaitBuffer(handle_, &image, &size, AT_INFINITE);
> function always immediately returns with error code 11 (which means AT_ERR_NODATA). The Andor3 driver ends up then calling AT_WaitBuffer repeatedly in a tight loop, causing giant log files, until we exit the IOC.
> The function should block until there is a data frame to read from the SDK, but it doesn’t, which is a problem. I’ve contacted Andor about this (and they asked me to update my SDK version from 3.9 to the latest version).
> Has anyone else also seen this problem?
> When I get chance I’ll try to reproduce it, and also update the SDK. I’m not sure if we can easily recover from this state, without restarting the IOC, but perhaps the Andor3 driver could detect this problem and set the ADStatus error flag. I’ll experiment with that if I can reproduce the problem.
> A bit suspiciously we also see an uncaught exception when we exit the IOC:
> 2016/09/22 19:46:04.402 andor3:imageTask: AT_WaitBuffer, error=11
> 2016[Thu Sep 22 19:46:07 2016] /09/22 19:46:04.402 andor3:imageTask: AT_WaitBuffer, error=11
> terminate called after throwing an instance of '[Thu Sep 22 19:46:07 2016] TSDK3Exception'
> [Thu Sep 22 19:46:07 2016]   what():  TDualCLLogicalControl: Error - Sensor halves are not running in unison
> Cheers,
> Matt
Andor SDK3 issue - AT_WaitBuffer fails Pearson, Matthew R.
RE: Andor SDK3 issue - AT_WaitBuffer fails Mark Rivers
Prev: RE: Andor SDK3 issue - AT_WaitBuffer fails Mark Rivers
Next: Re: Andor SDK3 issue - AT_WaitBuffer fails Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 23 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
