1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem in 3.14.12.5 with osd/WIN32/osdTime.h with latest version of MinGW
Date: Tue, 27 Sep 2016 13:23:15 +0000
I found a problem compiling 3.14.12.5 (with the msvs-timespec.patch) when building with the latest version of MinGW on Windows, which is gcc 5.3.0.
This is the error:
g++ -c              -D_MINGW     -O3   -Wall       -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix -I../../../src/
libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../
../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/
libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libC
om/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include         ../../../src/libCom/fdmgr/fdmgr.
cpp
In file included from ../../../src/libCom/osi/epicsTime.h:19:0,
                 from ../../../src/libCom/fdmgr/fdManager.h:27,
                 from ../../../src/libCom/fdmgr/fdmgr.cpp:29:
../../../src/libCom/osi/os/WIN32/osdTime.h:26:8: error: redefinition of 'struct timespec'
struct timespec {
In file included from ../../../src/libCom/osi/epicsTime.h:15:0,
c:\mingw\include\time.h:102:8: error: previous definition of 'struct timespec'
struct timespec
../../../configure/RULES_BUILD:218: recipe for target 'fdmgr.o' failed
make[1]: *** [fdmgr.o] Error 1
make[1]: Leaving directory 'P:/epics/epics/base-3.14.12.5/src/libCom/O.win32-x86-mingw'
../../configure/RULES_ARCHS:64: recipe for target 'install.win32-x86-mingw' failed
make: *** [install.win32-x86-mingw] Error 2
I was able to fix the problem by using the version of osdTime.h from base-3.15.4.
Also, to build areaDetector with MinGW the following change is needed in configure/os/, adding the winmm library.
-CONFIG.win32-x86-mingw.win32-x86-mingw:OP_SYS_LDLIBS = -lws2_32
+CONFIG.win32-x86-mingw.win32-x86-mingw:OP_SYS_LDLIBS = -lws2_32 –lwinmm
Re: Problem in 3.14.12.5 with osd/WIN32/osdTime.h with latest version of MinGW Ralph Lange
Prev: RE: Cross Compiling EPICS base for Xilinx Zynq, Petalinux- Recipe michael.abbott
Next: Re: Problem in 3.14.12.5 with osd/WIN32/osdTime.h with latest version of MinGW Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: printing value of pv to new line Hugo Slepicka
ANJ, 27 Sep 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
