You don't have to build sscan if you don't need the swait record. (You probably don't. The calcout record is better.) If you don't have the sscan module, you must comment out the
line that defines SSCAN, eg.
SSCAN=$(SUPPORT)/sscan-2-10-2
in calc/configure/RELEASE.
Tim Mooney ( [email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Hi Mike,
That error is not in StreamDevice, it is in calc. calc depends on sscan, so you must install and build sscan before you build calc.
On Behalf Of Michael Westfall
Sent: Thursday, October 06, 2016 12:23 PM
To: [email protected] Talk
Subject: StreamDevice fails to compile for RTEMS targets.
StreamDevice 2.6 fails to compile for RTEMS targets.
The problem seems to be with the example IOC in src/StreamDeviceApp/streamApp.
We get errors like these:
/home/mikew/epics/support/calc/lib/RTEMS-beatnik/libcalc.a(swaitRecord.o): In function `special':
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:553: undefined reference to `recDynLinkClear'
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:531: undefined reference to `recDynLinkAddInput'
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:539: undefined reference to `recDynLinkAddOutput'
/home/mikew/epics/support/calc/lib/RTEMS-beatnik/libcalc.a(swaitRecord.o): In function `inputChanged':
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:832: undefined reference to `recDynLinkGet'
/home/mikew/epics/support/calc/lib/RTEMS-beatnik/libcalc.a(swaitRecord.o): In function `pvSearchCallback':
/home/mikew/epics/support/calc/calcApp/src/O.RTEMS-beatnik/../swaitRecord.c:911: undefined reference to `recDynLinkConnectionStatus'
However, if I set the build to avoid cross compile targets, it builds OK for the Linux host.
Also it builds OK even for RTEMS targets if I comment out CALC=.... in .../configure/RELEASE.
Wondering if anyone else has run across this and what the solution might be..
Control Systems Software Engineer
- StreamDevice fails to compile for RTEMS targets. Michael Westfall
- RE: StreamDevice fails to compile for RTEMS targets. Mark Rivers
Fwd: StreamDevice fails to compile for RTEMS targets. Michael Westfall
<2016>
2025
2026
<2016>
2025
2026
ANJ, 06 Oct 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
