iocStats 1.1.15 available. Home page:
http://www.slac.stanford.edu/grp/ssrl/spear/epics/site/devIocStats/
Release Notes:
http://www.slac.stanford.edu/grp/ssrl/spear/epics/site/devIocStats/RELEASE_NOTES
Releases available via github:
https://github.com/epics-modules/iocStats
Many people have contributed to this module as you can see in the note for the last 2 releases:
iocStats-R3-1-15: Nov 3, 2016
* Changes by Mark Rivers:
- Improved the layout of the medm files to avoid overlapping widgets, etc.
- Added ioc_stats_reloadacf_confirm.edl to iocAdmin/srcDisplay/Makefile,
and put files in that Makefile in alphabetical order to help spot
missing files.
- Fixes for mingw compiler.
Define WINVER to be XP on MINGW to avoid compiler warnings.
Define WINVER to be XP (0x501) rather than WIN2K (0x500) for consistency.
* Changes by Keenan Lang:
- Define WINVER on MinGW.
* Changes by Tim Mooney:
- Don't build testIocStats unless SNCSEQ is defined in configure/RELEASE.
* Changes by Ronald Mercado:
- Fix devIocStatsGetPwd return value to make WIN32 consistent with posix.
* Changes by Jeong Han Lee:
- Replaced _SC_NPROCESSORS_CONF (The number of processors configured)
with _SC_NPROCESSORS_ONLN (The number of processors currently online).
* Changes by S. Allison:
- Use standard RELEASE file instead of LCLS-style RELEASE/RELEASE_SITE.
- Update .gitignore.
iocStats-R3-1-14: Apr 29, 2015
* Change to vxWorks osdFdUsage.c to not check the first 3 FDs by Scott Baily:
Unfortunately, the first 3 file descriptors on vxWorks are special
(standard in, standard out, and standard error). The pointers in
iosFdTable have the value FFFFFFFF. For 6.6 and above the reference
count isn't checked so there's no problem. But some of our systems use
6.3 and this code causes reads from page 0 of RAM.
* Change to add process ID and parent process ID records.
* Change to use github.
* Change to perform most statistics in a thread separate from record
processing.
Let me know of any problems within the next 2 months as I retire in January 2017.
Stephanie Allison
Re: EPICS Base Release-Candidate Double Feature! Bruce Hill
motor6-10 梁雅翔
<2016>
2025
2026
Control System Engineer at ESS David Brodrick
motor6-10 梁雅翔
<2016>
2025
2026
