1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base Release-Candidate Double Feature!
To: Andrew Johnson <[email protected]>, EPICS tech-talk <[email protected]>
Date: Fri, 11 Nov 2016 14:54:35 +0100
In the dynamic array support of PCAS, it does not handle gdd of container type. Here I put up a fix,
https://github.com/xiaoqiangwang/epics-base/commit/c76a2399ccf5bfb5f76a45ea56df360236d889aa
The reason of post gdd of container type is to workaround this bug,
https://bugs.launchpad.net/epics-base/+bug/1510955
Best
Xiaoqiang
On 11/01/2016 12:05 AM, Andrew Johnson wrote:
Ralph Lange and I have today tagged and generated Release Candidate[1]
versions of two new versions of EPICS Base for testing purposes. The
final releases of these will happen in about 2 weeks time provided no
major problems are reported in that period. Please report any problems
you find with these to this tech-talk mailing list.
Base-3.14.12.6-rc1
   See http://www.aps.anl.gov/epics/base/R3-14/12.php for the download
link and Release Notes.
Base-3.15.5-rc1
   See http://www.aps.anl.gov/epics/base/R3-15/5.php for the download
link and documentation.
These releases contain bug-fixes and various minor updates, and should
be compatible with software written for previous releases. See the
published Release Notes for details. Most of these modifications were
first applied to the Base-3.14 branch and the changes merged up to the
Base-3.15 branch.
One new feature that is present in both releases is that PCAS now
supports variable length array monitor updates — thanks to Matej
Sekoranja, Bruce Hill and Ralph Lange for implementing that.
The 3.15 branch does contain a major performance improvement to the IOC
when loading large numbers of database records.
Thanks to all the EPICS Core Developers for their work on these releases.
- Andrew Johnson
[1] Today's scary word for US residents
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Prev: Re: Native NI LabVIEW/EPICS integration Luca Cavalli
Next: Asyn readFloat64 not setting record value David Green
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Linking a HIGH and LOW field to a PV Hu, Yong
Next: Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
ANJ, 21 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
