1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: an easy quesiton about optics
To: l123173 <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 13 Nov 2016 15:13:03 +0000
The optics module does contain an iocBoot directory, and the src/ directory does contain an opticsMain.cpp.  However, the src/Makefile does not actually build a test application with opticsMain.cpp.
iocBoot/iocAny/st.cmd contains the lines:
dbLoadDatabase("../../dbd/iocxxxLinux.dbd")
iocxxxLinux_registerRecordDeviceDriver(pdbbase)
This looks like perhaps an example intended to be used in the synApps xxx module.
In any event, you will need to build a test application outside of the optic module.  You could use the synApps xxx module, or you could create your own.
From: [email protected] [[email protected]] on behalf of l123173 [[email protected]]
Sent: Sunday, November 13, 2016 8:43 AM
To: [email protected]
Subject: an easy quesiton about optics
Hi all,
    I use synApps(5.8) and Epics(3.14.15.3) for coupls of months and still puzzle sometime. Now I  am studying the motor and optics module.
    I try to use the optics to control the monochromator. I intend to start up the st.cmd in $(optics)/iocBoot/iocAny with the command : "  ../../bin/linux-x86_x64/....  " just like motor module.
    But I found the optics module did not have the /bin file and I make it with no error, so I could not use the command "../../bin/linux-x86_64".
    I wonder how could I use the optics module?
Li xing
an easy quesiton about optics l123173
Prev: an easy quesiton about optics l123173
Next: RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: mutex lock assertion failure Christian Pulvermacher
ANJ, 14 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
