1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MCA or LabCA on Linux-64bit
To: [email protected]
Date: Fri, 18 Nov 2016 07:40:18 -0800
Hi Giovanna.
I don't see any error messages (labCA build). We use labca regularly on 64-bit machines;
that shouldn't be an issue.
Best
- Till
On 11/18/2016 12:48 AM, Giovanna Campogiani wrote:
Dear colleagues,
I am trying to make the configuration files for MCA or LabCA on a Scientific Linux 64bit machine and I am get the errors at the bottom of the email.
While searching for an answer I learnt probably the problem is within the fact that both MCA and LabCA are for a 32 bit pc. How to make MCA and LabCA compatible for a 64 bit version of MATLAB?
Is this the real issue or am I missing something else?
Many thanks for your support,
best regards,
Giovanna
Errors reports
when trying to make MCA
/local/MATLAB/R2016b/bin/mex" -v -I/opt/codac-4.1/epics/base/include -I/opt/codac-4.1/epics/base/include/os/Linux -DEPICS_DLL_NO -L/opt/codac-4.1/epics/base/lib/linux-x86_64 -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp -O O.linux-x86_64/mca.mexglx
Verbose mode is on.
when trying to make LabCA
make -C ./configure install
make[1]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/configure/O.linux-x86_64'
perl /opt/codac-4.1/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/configure/O.linux-x86_64'
make[1]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/configure'
make -C ./ezca install
make[1]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca'
make[2]: Entering directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca/O.linux-x86_64'
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall     -g  -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../include/os/Linux -I../../include         ../ezca.c
make[2]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca/O.linux-x86_64'
make[1]: Leaving directory `/home/codac-dev/MATLAB/labca_3_5_0/ezca'
Giovanna Campogiani
Accelerator Physics PhD Student
Electronics Engineer
Sapienza University of Rome
INFN - National Institute of Nuclear Physics
MCA or LabCA on Linux-64bit Giovanna Campogiani
Prev: Re: MCA or LabCA on Linux-64bit Hinxx
Next: RE: MCA or LabCA on Linux-64bit Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MCA or LabCA on Linux-64bit Allison, Stephanie
Next: New areaDetector NDDriverStdArrays released Mark Rivers
ANJ, 21 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
