1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Linking a HIGH and LOW field to a PV
To: [email protected]
Date: Mon, 21 Nov 2016 15:00:40 +0100
Hi
I am trying to get "limits" to work on a "Soft Channel" record.
The challenge is that I have the limit values in another record, and want to make a link between the two records.
I would therefore like to something like this:
record(ao, "$(P):SUBCRYO_SETP_S") {
  field(DESC, "Huginn Sub-cryostat system setpoint")
  field(DTYP, "Soft Channel")
  field(VAL, "300")
  field(PREC, "3")
  field(EGU, "K")
  field(PINI, "YES")
  field(HSV, "MINOR")
  field(LSV, "MINOR")
  field(LOW, "$(P):SUBCRYO_SETP_MIN.VAL CP")
  field(HIGH, "$(P):SUBCRYO_SETP_MAX CP")
which, however, does not work.
It this possible, and in that case how.
Thanks in advance.
    Bo
EPICS Base Release-Candidate Double Feature! Andrew Johnson
RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Johnson, Andrew N.
Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
Prev: Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Next: RE: Linking a HIGH and LOW field to a PV Steiner, Mathias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 21 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
