1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Linking a HIGH and LOW field to a PV
Date: Mon, 21 Nov 2016 16:30:04 +0000
Wouldn’t a SEQuencer record be more appropriate for moving a bunch of values from one place  to another?
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
From: [email protected] [mailto:[email protected]] On Behalf Of Steiner, Mathias
Sent: Monday, November 21, 2016 9:13 AM
To: Bo Jakobsen <[email protected]>; [email protected]
The brute force approach would be to use a calcout...
record(calcout, "$(P):SUBCRYO_SET_LOW") {
  field(INPA, "$(P):SUBCRYO_SETP_MIN.VAL CP")
  field(CALC, “A”)
  field(OUT , "$(P):SUBCRYO_SETP_S.LOW PP")
..and similar for .HIGH.
It’s the opposite of elegant but it’ll work.
cheers -mathias
From: [email protected] [mailto:[email protected]] On Behalf Of Bo Jakobsen
Sent: Monday, November 21, 2016 09:01
To: [email protected]
Subject: Linking a HIGH and LOW field to a PV
Hi
I am trying to get "limits" to work on a "Soft Channel" record.
The challenge is that I have the limit values in another record, and want to make a link between the two records.
I would therefore like to something like this:
record(ao, "$(P):SUBCRYO_SETP_S") {
  field(DESC, "Huginn Sub-cryostat system setpoint")
  field(DTYP, "Soft Channel")
  field(VAL, "300")
  field(PREC, "3")
  field(EGU, "K")
  field(PINI, "YES")
  field(HSV, "MINOR")
  field(LSV, "MINOR")
  field(LOW, "$(P):SUBCRYO_SETP_MIN.VAL CP")
  field(HIGH, "$(P):SUBCRYO_SETP_MAX CP")
which, however, does not work.
It this possible, and in that case how.
Thanks in advance.
    Bo
Re: Linking a HIGH and LOW field to a PV Hu, Yong
EPICS Base Release-Candidate Double Feature! Andrew Johnson
RE: EPICS Base Release-Candidate Double Feature! freddie.akeroyd
Re: EPICS Base Release-Candidate Double Feature! Andrew Johnson
Re: EPICS Base Release-Candidate Double Feature! Johnson, Andrew N.
Re: EPICS Base Release-Candidate Double Feature! Matt Rippa
Prev: RE: Linking a HIGH and LOW field to a PV Steiner, Mathias
Next: Re: Linking a HIGH and LOW field to a PV Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Linking a HIGH and LOW field to a PV Bo Jakobsen
ANJ, 23 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
