1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Control system remote access
To: Mark Rivers <[email protected]>, epics Techtalk <[email protected]>
Date: Wed, 23 Nov 2016 02:15:48 +0000
Thank you for your reply, which is very useful to me.
Actually there is no strict limit for non-expert staff onsite.
Yingbing
On 11/22/2016 10:15 PM, Mark Rivers wrote:
> If you use ssh or VNC then you should be able to implement the same authentication policy from offsite as the one you use onsite?
> I typically use ssh if I need to access a Linux machine from offsite, and VNC if I need to access a Windows machine.
> How do you handle non-expert staff onsite?
> Mark
> From: 阎映炳 [[email protected]]
> Sent: Tuesday, November 22, 2016 8:00 AM
> To: Mark Rivers; epics Techtalk
> Dear Mark,
> I am considering the first case, which is used for the staff. But I want
> to introduce  some authentication policy. Not everyone is an expert :)
> Best regards,
> Yingbing
> On 11/22/2016 09:20 PM, Mark Rivers wrote:
>> Hi Yingbing,
>> I think you need to describe the desired usage more completely.
>> Is the remote access needed for SSRF staff to diagnose and fix problems from offsite?  Or is it for users to be able to conduct experiments and retrieve data remotely.
>> The first problem is much easier and we do it routinely at the APS.  Tools include ssh, VNC, etc.
>> The second problem is more difficult.  You need to worry about authentication, exactly what controls you can safely allow to be controlled from non-expert users remotely, etc.  Some beamlines at the APS do this, particularly the protein crystallography ones.
>> Mark
>> From: [email protected] [[email protected]] on behalf of 阎映炳 [[email protected]]
>> Sent: Tuesday, November 22, 2016 1:14 AM
>> To: epics Techtalk
>> Subject: Control system remote access
>> Hi,
>> The SSRF control system is based on EPICS. It has been operated more
>> than seven years. Recently the need for remote access (outside of the
>> gateway) became more and more urgent. I want to make a survey.
>> 1. Does your control system allow remote access ? Only monitor, or ... ?
>> 2. What is the best way to implement it?
>> 3. Is it possible to browse the archive data?
>> Thank you and best regards,
>> Dr. Yingbing YAN
>> Control Group  | SSRF | SXFEL
>> Shanghai Institute of Applied Physics, Chinese Academy of Sciences
>> No. 239 Zhangheng Road, Shanghai, China
Control system remote access 阎映炳
RE: Control system remote access Mark Rivers
Re: Control system remote access 阎映炳
Prev: Re: Linking a HIGH and LOW field to a PV Andrew Johnson
Next: Re: Linking a HIGH and LOW field to a PV Bo Jakobsen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Control system remote access Mark Rivers
Next: Re: Control system remote access Wesley Moore
ANJ, 23 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
